shifting raster cells
Malcolm Williamson malcolm at cast.uark.edu
Tue Jun 11 08:00:00 EDT 1996
Julie,
All of the responses that suggest that you edit the appropriate header
file under the $LOCATION/cellhd directory are correct. However, I wanted
to point out to you that if you are working in a projection (UTM, State
Plane, etc.), you cannot readily move in even lat/long increments, as 1
degree will be a different projected distance on different edges of your
raster file. You can readily move 100,000 meters, but not 1 degree. Of
course, if you're Location is set up in lat/long, you can move in degrees
to your heart's content. Just wanted to clarify!
Regards,
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Mon, 10 Jun 1996
julied at robinhood.ssmc.noaa.gov wrote:
> I have a raster file that I want to shift or move all the cells a specific di
stance. For example
> I want to move all the cells 1 degree latitude north, and 1 degree longitude
east. Does anyone
> know how to do that?
> Any help is appreciated.
> Thank you.
> Julie Daniel
> Physical Scientist
> National Weather Service
> email:  jdaniel at lionheart.ssmc.noaa.gov
