PROBLEM: d.mon fail on OSF/1
Tielin Zhang Tielin.Zhang at tvrl.lth.se
Tue Mar 26 07:00:00 EST 1996
Louis Clarke wrote:
> After removing the lock file, do you still have a monitor process running?
> (use ps -ef | more)
> Talk to you later.I'm not sure what you mean by "removing the lock file", but
 when I closed the x0
manually and left GRASS, there was NO monitor process running. Following is par
t
of list from "ps -ef":
USER       PID  PPID %CPU TTY             TIME COMMAND
root       510     1  0.0 ??           0:05.87 /usr/bin/X11/xdm -config /usr/l
root      5280   510  0.0 ??           6:19.87 /usr/bin/X11/X -nice -2 -auth /
captain   7774  7925  0.0 ??           0:00.03 sh /usr/var/X11/xdm/Xsession
root      7801   510  0.0 ??           0:01.12 -:0 (xdm)
root      7833     1  0.0 ??           0:00.09 /usr/bin/X11/dxconsole -geometr
captain   7921  8008  0.0 ??           0:00.01 sh -c /usr/bin/X11/dxconsole
captain   7923  8008  0.0 ??           0:00.92 /usr/bin/X11/mwm
root      7925   510  0.0 ??           0:00.44 -captain:0 (xdm)
captain   8008  7774  0.0 ??           0:00.39 dxsession
root      8009  7921  0.0 ??           0:00.35 /usr/bin/X11/dxconsole
root      8012  8008  0.0 ??           0:02.39 /usr/bin/X11/dxterm -ls
root       514     1  0.0 console      0:00.05 /usr/sbin/getty console console
captain   7993  8012  0.0 ttyp1        0:00.23 - (csh)
root      8064  7993  0.0 ttyp1        0:00.10 ps -ef
Actually I'm confused by "xdm" and "mdm", don't I need only one of them? Sorry
for
the basic Unix question instead of GRASS. Maybe I did some thing wrong when I
setup the pre-compiled binary of the GRASS, since the "install.script" file tha
t
comes with the binary gave me an error:
syntax error at line 177: `end of file' unexpected
and I could't fix it so that I did the install manually by running the sections
 of
the install.script (creating monitorcap, fifo, linking etc). Is there anything
more that need to be done?
Thanks for any help!
| Tielin Zhang PhD               |        ^-^    Q u o t e   ^-^    |
| Dept. Water Resources Eng.     |    "Still looking for good quote"|
| Lund Inst. of Technology       |E-mail: Tielin.Zhang at tvrl.lth.se  |
| University of Lund, SWEDEN.    |http://aqua.tvrl.lth.se/captain   |
