ps.map problem w.vectors in Linux
Simon Cox S.Cox at solo.ned.dem.csiro.au
Thu Mar 21 07:00:00 EST 1996
>The grass vector file format seems to be very wasty on
>disk space.  I had one which is about 50 MB, but only 30 MB in ARC/INFO.
>Maybe someone can work on a compressed version.
This is particularly the case if you have editted it, but not
run it through v.clean to remove all the deleted lines.  Just a reminder.
Simon Cox
_________________________________________________________
Dr Simon Cox                        __  \
CSIRO Exploration & Mining       ,~'  L_|\    Australian
39 Fairway, PO Box 437,       ;-'         \   Geodynamics
Nedlands, WA  6009  Australia (            \  Cooperative
      Phone +61 9 284 8443    +    ___     /  Research
      Fax   +61 9 389 1906     L~~'   "\__/   Centre
simon at ned.dem.csiro.au                   W
AGCRC info>>   http://www.ned.dem.csiro.au/AGCRC/
