Large plots on HP DesignJet 650c
Ronald Wiemer rwiem at archis.nl
Mon Nov 18 07:00:00 EST 1996
Although I can print GRASS ps.map images  on my hp 650c, I am not able to
produce large complex plots. When the PS file is bigger then about 7
megs, my plotter gives an out of memory message, and does not produce
any output at all. A solution that might solve the problem is by
using ghostscript. However, a sample plot produced by ghostscript only came
out partly correct. After a few proper looking inches, the plotter
produced garbage. I am quite sure that the binary file was not
converted to ascii or something like that,  so I suppose I have
configured ghostscript wrongly. Can someone give me a clue on how to
convert a postscript file to DesignJet HPGL?
Thanks,
Ronald Wiemer
R.O.B. / Archis
Kerkstraat 1
NL 3811 CV Amersfoort
The Netherlands
Tel: ++ 31 33 4634233
Fax: ++ 31 33 4653235
