conversion
christine.doolan at treebranch.com christine.doolan at treebranch.com
Mon Nov 18 07:00:00 EST 1996
Hello All,
I need to convert some files from grass to arcview3, which accepts dxf files.
when i convert my grass files to dxf, and try pulling them into arcview, the
attribute info isn't connected to the dxf file.  i've had trouble with this in
the past. does anyone know how to properly convert grass data to dxf?  if not,
any suggestions on converting from grass to arcview3 (making sure that the
attribute data is also converrted)?
Thank you!
Christine Doolan
