Angus Carr apcarr at FLASH.LakeheadU.CA
Tue Feb 4 07:18:06 EST 1997
If the file is in a raster by id number, you could run r.stats
to determine which are above the minimum size. The -a switch will
report size in square metres.
After that, it should be easy to rig up a reclass using r.reclass,
reclassing the smaller polygons to 0. If you need to do this
repeatedly, then a script to rig the reclass rules would not be hard
to code.
Angus Carr.
> I hope you have a simple answer to my hopefully simple question.  I have a
> file with around 1000 polygons.  I need to have displayed or selected only
> those polygons that are less than 1544 acres.  This file exists in vector
> and raster format.  What command in GRASS would be used to
> accomplish this?
