ps.map
Chris Cochran ccochran at tucson.ars.ag.gov
Thu Jan 9 17:07:28 EST 1997
I am operating grass4.1 on SPARC system 600 SUNOS2.5. When using ps.map,
I'll get a segmentation fault and core dump. This occurs both in the
interactive mode and as a script. The ps.select command appears to be
working ok. All other grass commands appear to work ok as well.
This problem cropped up after our system was upgraded to OS2.5. We need
a direct responce for this problem if at all possible. Thanks!
