d.mon under SOLARIS2.5
Malcolm Williamson malcolm at cast.uark.edu
Wed Jan 15 15:40:14 EST 1997
Hi, Gerhard
Every GRASS program (almost!) should have two different files installed,
one under a "cmd" directory and one under a "inter" directory. In this
particular case, I think you'll find that the file
$GIS/etc/bin/main/cmd/d.mon is not there; I'm not sure what would cause
this. If you need the file I can give you one.
	-Malcolm
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Wed, 15 Jan 1997, Gerhard Smiatek wrote:
> HI world,
> GRASS4.1 binaries  for SUN Solaris 2.5 from /outgoing work fine. But
> d.mon answers with: "Usage: d.mon (This command must be run interactively)
> hit RETURN -> "
> Does anyone know  how to fix that problem?
> Gerhard Smiatek
