importing ARC/INFO export format and STDS format
Henry Shin shin_hw at clark.net
Sat Jan 18 12:01:55 EST 1997
Phillip,
Thanks for the offer! I have not found anyone with Arc/Info yet. But, I am
going to try to import STDS formatted files first. If I can't work that
out. I might call upon your help. Thanks again.
Henry Shin
>Don't know about the STDS format, but you can forget about the export format,
>as there are no conversion tools available. I suggest you try to find
>someone who has Arc/Info to convert it to ungenerated format (if you can't
>find someone, send me an email and I'll I see if I can help you out).
>Philip Verhagen
>                     philip at raap2.ivambv.uva.nl
>                              R  A  A  P
>                        Plantage Muidergracht 14
>                          1018 TV Amsterdam
>                           The Netherlands
>                        tel: +31 (20) 421 62 00
>                        fax: +31 (20) 421 42 90
>                http://raap2.ivambv.uva.nl/home_eng.html
