problems with dxf
Ing. Alejandro Arcelus - IMFIA aarce at guille.fing.edu.uy
Fri Jul 25 07:52:13 EDT 1997
I don't have access to a list via news so I need a DIRECT RESPONSE to
aarce at fing.edu.uy
 Dear Sirs:
 I have digitized all contour lines from 1:50000 escale maps in autocad. I
export the files as dxf and use the program v.in.dxf in order to convert
the file to GRASS vector format. Unfortunaly the program gives me the
following messages
 CONVERSION OF /imfia04/usr/aarce/dos/dwg/e22-247.dxf TO DIG FILE:
making arc: offset 1 x 624.9 y 6275.3 rad -0.2 a1 117.9 a2 116.9 1
making arc: offset 3 x 625.0 y 6275.4 rad -0.2 a1 116.9 a2 104.1 1
making arc: offset 7 x 624.9 y 6275.8 rad 0.2 a1 284.1 a2 288.5 1
making arc: offset 9 x 625.0 y 6275.8 rad 0.2 a1 288.5 a2 292.8 1
making arc: offset 11 x 625.0y 6275.8 rad 0.2 a1 292.8 a2 294.5 1
making arc: offset 13 x 625.2 y6275.5 rad -0.2 a1 114.5 a2 109.5 1
making arc: offset 16 x 625.2 y 6275.9rad 0.2 a1 289.5 a2 300.0 1
making arc: offset 20 x 625.4 y 6275.5 rad-0.2 a1 119.9 a2 118.0 1
making arc: offset 22 x 625.4 y 6275.5 rad -0.2a1 118.0 a2 103.6 1
and so on... until it finishes with:
making arc: offset 2515 x 626.7 y 6282.0 rad -0.1 a1 260.0 a2 228.6 1
making arc: offset 2523 x 626.5 y 6281.8 rad 0.2 a1 408.6 a2 431.8 1
making arc: offset 2529 x 626.5 y 6281.8 rad 0.1 a1 431.8 a2 448.5 1
making arc: offset 2534 x 626.5 y 6282.1 rad -0.2 a1 268.5 a2 238.7 1
making arc: offset 2541 x 626.5 y 6282.2 rad -0.2 a1 238.7 a2 218.9 1
making arc: offset 2546 x626.5 y 6282.2 rad -0.2 a1 218.9 a2 205.2 1
making arc: offset 2550 x 626.1 y 6282.1 rad 0.2 a1 385.2 a2 423.5 1
ERROR: G_realloc: out of memory
What can be the problem?
Doesn't supose to say convering ...% of dxf file or something similar?
The dxf file has 4MB. Is it too big?
I tried with a smaller file  (360 KB) and the result was the same.
I tried, and the dxf file is able to be converted back completly to
autocad format (so I guess the file is not the problem).
Thanks, and regards
					Eng. Carlos Arcelus
