Map Projections
Malcolm Williamson malcolm at cast.uark.edu
Fri Jun 13 10:24:06 EDT 1997
Hi, Roy
Create a new lat-long Location, and digitize your maps in that Location.
Use v.proj to re-project the lat-long maps to UTM in your other Location.
Hint: both Location should be under the same directory (GRASS
"Database"), though you can always resort to symbolic links if you don't
have enough physical disk space. Happy digitizing,
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
On Fri, 13 Jun 1997,
R.A.Sanderson wrote:
> Dear Grass Users,
> Is there a simple way of using two map projections simultaneously in GRASS?
>  I have a GRASS location in UTM, but need to add new maps by digitising
> from base maps stored as latitude-longitude.  The v.digit command only
> seems able to cope with digitising using the same projection as the
> original location (in this case UTM). I could resort to using Arc/Info for
> digitising, then PROJECT/TRANSFORM into UTM before exporting to GRASS, but
> I'd prefer to carry out the whole operation in GRASS if possible.
> Cheers
> Roy
> Roy Sanderson
> Centre for Land Use and Water Resources Research
> Porter Building
> University of Newcastle
> Newcastle upon Tyne
> NE1 7RU
> United Kingdom
> Tel: +44 191 222 7789
> Fax: +44 191 222 6563
> URL: http://www.cluwrr.ncl.ac.uk
