unlocking x0,x1,etc
Malcolm Williamson malcolm at cast.uark.edu
Fri Jun 13 17:27:20 EDT 1997
On Fri, 13 Jun 1997, Peizhong Wu wrote:
> The happened to me also. Even I killed the processes, I could not run x0
> again. Seems there is a lock file somewhere that control the devices.
This would be a lock file under $GISBASE/locks/<machine_name>/. The
difficulty is in associating the correct lock file with the monitor. If
you can be sure that all monitors have been stopped that are running
from a particular machine, you can simply remove all lock files under
that machine name.
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
> Peizhong
> University of Michigan
> On Fri, 13 Jun 1997, Paul W. Box wrote:
> > Milton Cezar Ribeiro wrote:
> > > Dear friends:
> > > I have installed my grass under solaris now.
> > > But, on my 1st time that I exited from grass-shell
> > > I forgot two (x0-x1) display monitor active and
> > > now I can't use this two monitor on other sessions!
> > Could you use the ps command (from the unix shell), find which processes
> > are running x0 and x1, and use the kill command to shut them down?
> > /*  Paul Box                      |        Cogito ergo                */
> > /*  Dept. of Geography            |      Oculum Dioscoreum            */
> > /*  University of Florida         |                                   */
> > /*  sanduku at nervm.nerdc.ufl.edu   |     (I think, therefor            */
> > /*  http://grove.ufl.edu/~sanduku |           eye yam)                */
