Problem with sites.c in fp_sites_datetime-3.tar
Justin Hickey jhickey
Mon Jun 16 07:21:27 EDT 1997
Hello all
I'm trying to compile GRASS with the floating point code and have come across a
problem. I first downloaded the fp_main and fp_alpha files off the floating
point outgoing directory and tried compiling them as per the readme file on the
site. However, when compiling the d.sites command
($GIS/src/display/d.sites/cmd) the linker complained that the "datetime"
library was not found. Further search on the floating point ftp site found the
file fp_sites_datetime-3.tar and I downloaded it. Now when compiling the
d.sites command the linker says that two functions are undefined in the file
$GIS/src/libes/gis/sites.c.
Upon inspection, it turns out that there are two versions of the sites.c file
in the floating point code: one from fp_main and the other (a newer version)
from fp_sites_datetime-3. The only difference between the two files is the last
revision of the sites.c file indicated below from the file itself:
Revision 1.40  1996/05/23  brown
 * changed DateTime stuff to use TimeStamp instead
The two undefined functions the linker is complaining about (namely
G_format_timestamp and G_scan_timestamp) were introduced by this revision.
However, a recursive grep through the GRASS directory tree indicates that these
functions are not defined anywhere.
I originally thought that the reference to "brown" in the revision comment was
a reference to Bill Brown, the webmaster of the GRASS web pages (the original
author was Darrell McCauley). However, an e-mail to him has gone unanswered
(maybe he's on vacation). So I've turned to the ever helpful GRASS experts.
Does anyone know where I can obtain these two functions? Should someone add
these functions to the fp_sites_datetime-3.tar file on the ftp site? Or should
I just revert back to the sites.c file in the fp_main file and hope it doesn't
break the code in the fp_sites_datetime-3 file? Has anyone successfully
compiled the floating point code?
Any information would be greatly appreciated and thank you for your time and
effort in this matter.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
