monitor
Malcolm Williamson malcolm at cast.uark.edu
Sun Mar 9 22:15:53 EST 1997
Hi, Francisco
You should be able to remove the lock file with the rm command, and then
try starting the monitor again.
	-Malcolm Williamson
On Sun, 9 Mar 1997 fncesbl at bu.edu wrote:
> Hi,
> I am suddenly unable to open the x0 monitor.
> after the d.mon start=x0 command I get this message:
> Graphics driver [x0] started
> Error - Could not complete locking process for monitor <x0>.
> Lock file is /usr/local/grass-4.1/locks/atacama/mon.20503
> Problem selecting x0. Will try once more
> and I am unable to display anything.
> Can someone please help me undo this?
> I noticed that the file  /usr/local/grass-4.1/locks/atacama/mon.20503 is
> actually empty.
> I was able to use an x1 monitor though, and there is a mon.20505 in that same
> locks directory.
> I just would like to get some assistence if possible, to prevent
> further problems.
> Thank you
> Francisco Estrada Belli
> Boston UNiversity
> Dept. of Archaeology
