sites & elevation map
Philip Verhagen philip at raap2.ivambv.uva.nl
Fri Mar 14 05:27:32 EST 1997
> I did a GRASS site list file for a zone and now i have an elevation map
> for the same zone.
> Problem: how can i obtain a new site list file (or anything else) with also
> 	 the altitude for these sites?
Use s.menu option 8 - Run Reports; choose option 4 - Produce
machine readable data file; this will give you the raster value of the
elevation for each site. Unfortunately, the output is not in site_list format,
so you'll need to manipulate the resulting file into a GRASS site list.
Option 1 - Site characteristics report will give you a list in a more
friendly format, but which will be more difficult to manipulate.
Hope this helps,
Philip Verhagen
                              R  A  A  P
                        Plantage Muidergracht 14
                          1018 TV Amsterdam
                           The Netherlands
                        tel: +31 (20) 421 62 00
                        fax: +31 (20) 421 42 90
                http://raap2.ivambv.uva.nl/home_eng.html
