v.support
etep at etep.dsnet.it etep at etep.dsnet.it
Fri Mar 28 13:07:41 EST 1997
I am in trouble using v.support command because I cannot make clear about
the methods used to build areas and isles.
Following you can find a few little examples (dig_ascii file format) where
the results are not clear:
Example 1:
A  5
  1.0    1.0
  1.0    3.0
  3.0    3.0
  3.0    1.0
  1.0    1.0
-->	Aree: 1
	Isole: 1
Example 2:
  1.0    1.0
  1.0    5.0
  5.0    5.0
  5.0    1.0
  1.0    1.0
A  5
  2.0    2.0
  2.0    4.0
  4.0    4.0
  4.0    2.0
  2.0    2.0
-->	Areas: 2
	Isles: 2
Example 3:
A  5
  1.0    1.0
  1.0    5.0
  5.0    5.0
  5.0    1.0
  1.0    1.0
A  2
  1.0    1.0
  2.0    2.0
-->	Areas: 0
	Isles: 1
Examples 4:
A  5
  1.0    1.0
  1.0    5.0
  5.0    5.0
  5.0    1.0
  1.0    1.0
A  2
  1.5    1.5
  2.0    2.0
-->	Areas: 1
	Isles: 1
Examples 5:
A  5
  1.0    1.0
  1.0    5.0
  5.0    5.0
  5.0    1.0
  1.0    1.0
A  2
  5.0    5.0
  4.0    4.0
-->	Areas: 1
	Isles: 1
Probably a detailed programmers documentation about isles and areas could
help me to understand how v.support works. Could someone help me to find it ?
Thank You in advance!
Elena
ET&P Srl
Via Musolesi, 1/a
I-40138 Bologna (ITALY)
Phone +39-51-392350/60
Fax   +39-51-392348
E-mail etep at etep.dsnet.it
