i.rectify
Malcolm Williamson malcolm at cast.uark.edu
Fri Sep 26 11:11:56 EDT 1997
On Thu, 25 Sep 1997, Jean-Marc Chofflet wrote:
(deleted lines)
> My first step was to digitize each of the images in CorelXARA (vectorial
> software)
> and try to fit the pieces together : some distorsions were too important
> so I've used
> i.rectify2 under GRASS, then produced 15 rectified images. I've tried
> again under CorelXARA :
> again some distorsions (not the same ones). So I r.patched my rectified
> images to produce
> one image : it works (almost perfectly)! My question is : does r.patch
> do more then just
> connecting the pieces together or did I misused CorelXARA when I tried
> to join the rectified
> images "by hand"?
r.patch is real simple - it just takes the list of input maps, starting
with the first one, and copies the data to a new raster layer, with each
successive map only being able to add data where there was _not_ data
from an earlier map in the input list. In other words, the first map will
overlap the second one, the second will overlap the third, and so on
(assuming that there is a degree of overlap between input raster layers).
It doesn't adjust the data in any way. Hope that helps,
	-Malcolm
>  Thanks again
> *     JM Chofflet                                 *
> *     ERA 41 du CNRS       7, rue Gaston Couté    *
> *     3, rue Michelet      F75018 Paris           *
> *     F75006 Paris                                *
> *     tel off. : +33 (0)1 53 73 71 08             *
> *     tel home : +33 (0)1 46 06 88 59             *
> *     fax      : +33 (0)1 44 07 01 79             *
> *     Mailto:chofflet at asterix.univ-paris1.fr      *
