ERDAS to GRASS
Tom Meixner tom at hwr.arizona.edu
Tue Apr 7 18:30:58 EDT 1998
I am using GRASS4.2 for a research project I am
working on in Colorado.  My colleagues tend to
use ERDAS alot and I need to convert some images
from ERDAS into GRASS format.  I have been trying
to use the i.in.erdas command to do this but with
little success.  Most of the images I need to
convert have only 1 band so there is really
little conflict in the conversion.
Whenever I run i.in.erdas I get an error stating
that the ERDAS file cannot be opened.  I have a
feeling I have the ERDAS file in the wrong place
or in the wrong format.  I have tried a number of
different ways to do this conversion all to know
avail.  Thanks for your help.
Thanks,
Tom Meixner
I have included below a transcript of the process
I have used:
Mapset <tomin Location
<GLV>
GRASS 4.2 i.in.erdas
FLAG: Set the following flag?
    List the ERDAS header only?(y/n) [n] n
OPTION:   Erdas input file name
     key: input required: YES enter option >
sca042294.img
You have chosen:
  input= sca042294.img Is this correct? (y/n) [y]
OPTION:   output prefix of the GRASS raster files
to be created.
     key: output required: YES enter option >
sca042294
You have chosen:
  output= sca042294 Is this correct? (y/n) [y]
OPTION:   Erdas trailer input file name
     key: trailer required: NO enter option img
You have chosen:
  trailer=img Is this correct? (y/n) [y] n enter
option >
OPTION:   Selected bands to extract.
     key: bands required: NO multiple: YES enter
option >
OPTION:   Starting row.
     key: srow required: NO enter option >
OPTION:   Starting column.
     key: scol required: NO enter option >
OPTION:   Number of rows to extract.
     key: rows required: NO enter option >
OPTION:   Number of columns to extract.
     key: cols required: NO enter option Error
can not open ERDAS file
