Importing ArcInfo files
taravudh taravudh at hpcc.nectec.or.th
Wed Aug 19 21:25:44 EDT 1998
Hi Stephan,
You should use some commands from ArcInfo so that you will able to
change them to GRASS environment. Firstly,you have to tranfer all files
which are e00 format to Arcinfo format. Secondly, you should use
ungenerate command for changing all transfered data.
In each step for using ungenerate command can be provided as follows :
1)polygon files.(suppose that it's A.pat)
	- ungen [LINE/POINT] [cover] [file]
		* ungen LINE A test1.lin
		* ungen POINT A test1.pot
		* you should use Excel program for changing A.dbf to A.txt by using
save as command.
*** The result is test1.lin, test1.pot and A.txt.***
2)vector files.(suppose that it's B.aat)
		* ungen LINE A test2.lin
		* To use Excel for changing like previous step
*** The result is test2.lin and B.txt.***
After you already process all data, you can use V.IN.ARC exactly.
Good Luck.
Taravudh
Stephan Eickschen wrote:
> Hi all,
> I have downloaded some data from the Antarctic Digital Database
> (http://www.nerc-bas.ac.uk/public/magic/add_main.html). They are
> supposed to be ArcInfo files containing coastlines, surface featuers
> and so on. But I really do not know how to import them into GRASS. I
> attach the reult of
> head *.e00 >! ADD.ArcInfo.files
> If someone needs the complete file(s), please feel free to look at
>         http://earth.uni-muenster.de/~eicksch/ftp/GRASS_DATA/
> There you will find all of them.
> Any suggestion will be highly appriciated,
>         Stephan
> Stephan Eickschen                     Tel. : +49 (0)251 83-34704
> Westfaelische Wilhelms-Universitaet   Fax. : +49 (0)251 83-36100
> Institute for Geophysics
> Research Unit of Physical Glaciology  email: eicksch at uni-muenster.de
> Corrensstrasse 24
> 48149 Muenster
> Germany
> ==> coast00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/COAST00.E00
> ARC  2
>          1-999999999         1         2         1         2         2
> -4.9950791E+05 2.3500000E+06 0.0000000E+00 2.3500000E+06
>          2-999999999         3         2         2         1        29
>  0.0000000E+00 2.2290530E+06 0.0000000E+00 2.2304160E+06
>  0.0000000E+00 2.2348970E+06 0.0000000E+00 2.2393780E+06
>  0.0000000E+00 2.2438600E+06 0.0000000E+00 2.2483420E+06
>  0.0000000E+00 2.2528240E+06 0.0000000E+00 2.2573070E+06
>  0.0000000E+00 2.2617910E+06 0.0000000E+00 2.2662760E+06
> ==> cont00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/CONT00.E00
> ARC  2
>          1         1       666       666         0         0         7
> -1.0512750E+05 2.0463910E+06-1.0516720E+05 2.0464340E+06
> -1.0526590E+05 2.0463610E+06-1.0525150E+05 2.0463110E+06
> -1.0517540E+05 2.0463130E+06-1.0511980E+05 2.0463600E+06
>          2         2         7         6         0         0        11
> -1.5344000E+05 2.0384920E+06-1.5349930E+05 2.0385250E+06
> -1.5355770E+05 2.0385410E+06-1.5366391E+05 2.0386100E+06
> ==> elevn00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/ELEVN00.E00
> LAB  2
>      14655         0-4.5259441E+04 2.0731460E+06
> -4.5259441E+04 2.0731460E+06-4.5259441E+04 2.0731460E+06
>      14631         0-1.4422070E+04 2.0700910E+06
> -1.4422070E+04 2.0700910E+06-1.4422070E+04 2.0700910E+06
>      14630         0-9.4989424E+03 2.0589660E+06
> -9.4989424E+03 2.0589660E+06-9.4989424E+03 2.0589660E+06
>      14632         0-9.5950453E+04 2.0488880E+06
> -9.5950453E+04 2.0488880E+06-9.5950453E+04 2.0488880E+06
> ==> gflow00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/GFLOW00.E00
> ARC  2
>          1      3157       108       109         0         0        54
> -2.2231580E+05 2.0378300E+06-2.2241420E+05 2.0376390E+06
> -2.2251650E+05 2.0373910E+06-2.2255459E+05 2.0372530E+06
> -2.2273950E+05 2.0370390E+06-2.2283391E+05 2.0369040E+06
> -2.2295059E+05 2.0368560E+06-2.2336080E+05 2.0366580E+06
> -2.2404870E+05 2.0365370E+06-2.2430809E+05 2.0364700E+06
> -2.2471830E+05 2.0362730E+06-2.2509841E+05 2.0361020E+06
> -2.2533159E+05 2.0360050E+06-2.2550859E+05 2.0359040E+06
> ==> gmarg00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/GMARG00.E00
> ARC  2
>          1     14760         5         6         0         0        27
> -1.6392189E+04 2.0004290E+06-1.6628439E+04 1.9999090E+06
> -1.7212189E+04 1.9985080E+06-1.8106189E+04 1.9967350E+06
> -1.8737939E+04 1.9954520E+06-1.9004320E+04 1.9949060E+06
> -1.9373689E+04 1.9941120E+06-1.9936689E+04 1.9929940E+06
> -2.0752439E+04 1.9911300E+06-2.0954320E+04 1.9906920E+06
> -2.1151939E+04 1.9903110E+06-2.2130939E+04 1.9881480E+06
> -2.2939570E+04 1.9867650E+06-2.3381689E+04 1.9857510E+06
> ==> human00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/HUMAN00.E00
> LAB  2
>         21         0-3.0446700E+05 2.0998723E+06
> -3.0446700E+05 2.0998723E+06-3.0446700E+05 2.0998723E+06
>         34         0-9.9186469E+04 2.0041411E+06
> -9.9186469E+04 2.0041411E+06-9.9186469E+04 2.0041411E+06
>         -1         0 0.0000000E+00 0.0000000E+00
> TOL  2
>          1         2 2.0528053E+01
>          2         2 0.0000000E+00
> ==> moran00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/MORAN00.E00
> ARC  2
>          1     13164         1         1         2         1        14
> -1.1199340E+05 1.9802780E+06-1.1202330E+05 1.9803510E+06
> -1.1203330E+05 1.9804090E+06-1.1208930E+05 1.9805880E+06
> -1.1211000E+05 1.9807150E+06-1.1215200E+05 1.9807760E+06
> -1.1220560E+05 1.9808170E+06-1.1226360E+05 1.9808320E+06
> -1.1229260E+05 1.9807860E+06-1.1232360E+05 1.9805800E+06
> -1.1231580E+05 1.9804540E+06-1.1225750E+05 1.9803370E+06
> -1.1214150E+05 1.9802110E+06-1.1199340E+05 1.9802780E+06
> ==> rock00.e00 <==
> EXP  0 /LOCAL1/DATA/BSMAPS/ADD/CARTO/SCALE0/SR29_30/ROCK00.E00
> ARC  2
>          1     14698         1         1         2         1        12
> -1.0508310E+05 2.0463910E+06-1.0510670E+05 2.0464490E+06
> -1.0522360E+05 2.0465130E+06-1.0528050E+05 2.0465050E+06
> -1.0531680E+05 2.0464590E+06-1.0532610E+05 2.0463770E+06
> -1.0529270E+05 2.0463330E+06-1.0524690E+05 2.0462970E+06
> -1.0518880E+05 2.0462680E+06-1.0512520E+05 2.0462700E+06
> -1.0509520E+05 2.0463150E+06-1.0508310E+05 2.0463910E+06
>          2     13083         2         2         3         1         7
