ps.map - segmentation fault
J. HOLLENBECK jhollenb at nmsu.edu
Fri Aug 21 14:17:16 EDT 1998
Michael-
	Yes I had the same problem.  I fixed it using a fix posted to the
list some time ago...
You need to put the definition  #include <stdlib.h>  in
/src.alpha/ps.map/ps.map/cmd/read_cfg.c  and then compile ps.map as usual
(using -fwritable-strings of course).
Hope this helps.
Jeff P. Hollenbeck
Dept. of Fishery and Wildlife Sciences
New Mexico State University
On Fri, 21 Aug 1998, Michael Schulz wrote:
> Dear Grassers !
> I have Linux-source-code v17 compiled, recompiled ps.map with
> COMPILE_FLAGS = -O -fwritable-strings.
> After MAKELINKS.my and starting GRASS, ps.map is still crashing with
> segmentation fault.
> What can i do? Anybody had same problem?
> Thanks, Michael
> Michael Schulz
> Christoph-Mang-Str.5       Geologisches Institut
> 79100 Freiburg             Universitaet Freiburg
>                            Albertstr. 23b
>                            79104 Freiburg
