advice to novice
Stephan Eickschen eicksch at uni-muenster.de
Mon Aug 31 08:49:29 EDT 1998
Hi David,
> The problem is that bash returns 'grass4.2:cannot find command' when I
> issue the 'grass4.2' command in /usr/local/grass42/ , and in
> /usr/local/bin.
what gives 'ls -l grass4.2' in /usr/local/grass42/ or /usr/local/bin
resp.?
it should be something like
-rwxr-xr-x    1 grass    staff        106 Aug  3 13:40 grass4.2*
Did you try something like './grass4.2' in the named directories? (Incl.
the dot and the slash).
Just tell us, what you get :-)
Regards,
	Stephan
Stephan Eickschen                     Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet   Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology  email: eicksch at uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
