Grass and glibc6
Michael Schulz schulzm at perm.geologie.uni-freiburg.de
Fri Dec 11 05:46:52 EST 1998
On Tue, 8 Dec 1998, Adalberto da Silva wrote:
> > As I'm putting another machine to run I'm trying to install Grass  *and*
> > Debian 2.0 because there are some good programs using libc6.
> > But when I tried to run Grass under X I just got this message:
> > "/usr/local/grass42/etc/GIS.sh: line 47: 2560    segmentation fault
> > $ETC/gis_set"
> > If I run Grass from a 'normal' terminal it works (and it works well I
> > must point out!) but... Well, anyone wants a good and coloured screen
> > filled with those colourful maps...
> Adalberto da Silva
Hello Adalberto !
We had the same problem on one of our machines. By default, Debian uses a
special xterm (Debian-xterm), which seemed to cause the problem we had
(same segmentation fault).
Try using the "standard xterm" (information about that in
/usr/doc/X11/README-Debian). Hope this helps !
Michael Schulz
Geologisches Institut
Universität Freiburg
mschulz at ruf.uni-freiburg.de
www.geologie.uni-freiburg.de/root/people/studis/schulzm/schulzm.html
