A couple simple questions
Bruce Nielsen bnielsen at in.nrcs.usda.gov
Tue Dec 29 07:47:56 EST 1998
Skip Haak wrote:
[question 1 deleted]
> (2) To learn the program I decided to download similar types of data I would
> be using in real life, import the data into GRASS, and then manipulate the
> data using different modules. One set of data I am trying to work with is
> the National Wetland Inventory data from the U.S. Fish and Wildlife Service.
> I have DLG data for a 7.5 min USGS quad that I want to import into GRASS. My
> problem isn't what module to use or how to use the module but where to store
> the data. Everytime I run v.in.dlg, I get the error message "No DLG files
> found" or something like this. If my directory structure is
> /home/skip/grass_data, should I store the DLG file here or in the
> subdirectories labeled ENTIRE or PERMANENT? I've copied the files to all the
> directories with the same results. I have even tried to specify the path and
> filename but got a segmentation fault. What do I do?
> Any and all help is very much appreciated.
> Thanks, Skip Haak
Put your DLG files in $LOCATION/dlg.  v.in.dlg looks there
automatically.
Type: text/x-vcard
Desc: Card for Bruce Nielsen
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19981229/6ad9e000/bnielsen.vcf
