Labeling Areas-Part 2
Adalberto da Silva adalbert at iag.usp.br
Tue Feb 3 09:12:34 EST 1998
Hello,
	I'm reposting this message because I got some major problems with my
mail server and my Linux box (and I have lot of messages not delivered
for a couple of months).
	Sorry if this message is being repeated or quite out of date.
	Adalberto
#####Original Message#####
Shawn Francis wrote:
>         GRASS is kind of funny in that it handles LINES and AREA EDGES
> separately.  LINES are for the representation of linear features while AREA
> EDGES, as the name suggests, are used to form polygon boundaries.  To get
> your DXF lines into polygons, you will have to "toggle line type" in the
> EDIT menu of v.digit.  Then you will be able to create a polygon.  This can
> also be done by text editing the vector ascii file, but for such a small
> file the v.digit option is probably faster.  Hope this helps.
> Shawn Francis,
> Forest Ecologist and GIS Analyst
> Applied Ecosystem Management
> 100-114 Galena Road
> Whitehorse, Yukon  Y1A 2W6
> tel/fax (867) 393-3793
> aem at yknet.yk.ca
	It works, Shawn!
	But, as you said, this applies only for this kind of very small job.
	So, I'll ask you in advance.
	In a couple of days I'll put a large geologic map on top of my digital
terrain model. And this is not a matter of a half-dozen pretty good
rectangles.
My primary source is Autocad drawings and I may get a huge dxf file with
as many
as we can realise polygons with very strange forms...
	How can I edit the vector ascii file in order to convince Grass that my
former Autocad areas are real & good closed areas that I can attach a
label?
	Many thanks,
Adalberto da Silva
Instituto Astronomico e Geofisico - USP
Sao Paulo - Brasil
