compiling grass-jni-0.7.0 on Linux
Herve Dreau hdreau at worldnet.fr
Mon Jul 20 18:33:20 EDT 1998
Hello,
I'm trying to compile grass-jni-0.7.0 on a Linux Box (Redhat 5.1) and
I have some troubles when compiling  libgis.so (same problems when
trying to compiling libvect.so)
I know that this 'library' is only tested with SunOS 5.5.1, and my
problem's are more Linux (and java Linux) related than due to Grass,
but I don't know a better group to post my questions.
(In the GNUMakefile I replace (JDK_HOME)/include/solaris by
(JDK_HOME)/include/genunix)
this one :
GRASS_FILE.c: In function `FILE_ptr':
GRASS_FILE.c:38: warning: cast to pointer from integer of different
size             -------------------------------------------------
 (repeated a lot [I think it's a problems with declaration in
(JDK_HOME)/include/genunix/jni_md.h] ):
and this one :
gcc -g -O2 -I/usr/local/jdk1.1.6/include
-I/usr/local/jdk1.1.6/include/genunix
-I/usr/local/grass42/src421/src/include
-I/usr/local/grass42/src421/src/mapdev/Vlib
-I/usr/local/grass42/src421/src/mapdev/diglib
-I/usr/local/grass42/src421/src/include -DUSE_TERMIO -c jmalloc.c -o
jmalloc.o gcc -g -I/usr/local/jdk1.1.6/include
-I/usr/local/grass42/src421/src/mapdev/diglib -Wl,-s -o libgis.so \
        GRASS_libgis.o GRASS_CELL.o GRASS_Cellhead.o GRASS_Colors.o
GRASS_FD.o GRASS_Range.o GRASS_Cellstats.o GRASS_Categories.o
GRASS_FILE.o jmalloc.o -L/usr/local/grass42/src421/src/libes/LIB.linux
-lgis
/usr/local/grass42/src421/src/libes/LIB.linux/libgis.a(gets.o): In
function `G_gets': gets.o(.text+0x5f): the `gets' function is
dangerous and should not be used.
 /usr/lib/crt1.o(.text+0x36):
undefined reference to `main' make: *** [libgis.so] Error 1
Is it a problems whith a missing library for the linkage?
If someone had compiling and use grass-jni-0.7.0 on Linux, I d like to
read the tips ( I want to use java servlet to use Grass  on an HTTP
server for Rabies surveillance , who is nearly totaly based on java
classes and for now i can't use Grasslinks)
also I notice the warning about the use of gets in a great number of
file when i'm compilling Grass (V 4.2.16) Is it due to the use of
glibc (aka libc.so.6) ???
Thank you.
Hervé Dréau Interne en Médecine
hdreau at worldnet.fr dreau at hbroussais.fr
Médecine Linux Java
