GRASS on SGI
David Wheatley D.W.Wheatley at soton.ac.uk
Thu Jul 30 13:28:22 EDT 1998
Stephan,
Your header looks good, but as I said in my post you should get flex and
bison for your system to replace lex and yacc - they are gnu freeware,
and resolve some of the compilation problems. Both compiled without a
warning on my octane with 'make configure;make;make install'
David
PS I use the -w flag to turn off all the warnings!
Header follows:
CC                  = cc
YACC                = bison -y
LEX                 = flex
#LEXLIB              = -lfl
ARCH                = sgi
GISBASE             = /usr/local/grass42
UNIX_BIN            = /usr/local/bin
DEFAULT_DATABASE    =
DEFAULT_LOCATION    =
COMPILE_FLAGS       = -O -cckr -w
LDFLAGS             = -s
XCFLAGS             = -D_NO_PROTO -DXM_1_1_ BC -Umips
XLDFLAGS            = -lPW -ll
XINCPATH            =
XMINCPATH           =
XLIBPATH            =
XTLIBPATH           = -L/usr/lib -L/usr/local/lib
XMLIBPATH           = -L/usr/lib -L/usr/local/lib
XLIB                = -lX11
XTLIB               = -lXt
XMLIB               = -lXm
XEXTRALIBS          = -lPW -ll
TERMLIB             = -ltermlib
CURSES              = -lcurses $(TERMLIB)
MATHLIB             = -lm
#                   LIBRULE = ar ruv $@ $?
#                   LIBRULE = ar ruv $@ $?; ranlib $@
#                   LIBRULE = ar ruv $@ $?; ar ts $@
#                   LIBRULE = ar rc $@ `lorder $(OBJ)
USE_TERMIO          = -DUSE_TERMIO
USE_MTIO            = -DUSE_MTIO
USE_FTIME           =
DIGITFLAGS          = -DUSE_SETREUID -DUSE_SETEUID -DUSE_SETPRIORITY
VECTLIBFLAGS        =
GETHOSTNAME         = -DGETHOSTNAME_OK
XDRLIB              = -lsun
Stephan Eickschen wrote:
> Hi David,
> > Incidentally, it compiled fairly cleanly for me using the SGI
> > compiler and the -cckr option ... the main problems were with lex
> > (get flex) and yacc (get bison and use bison -y). I didn't change
> > any source code at all.
> I tried it, but I got stuck much earlier with flex and yacc. Or have I
> to delete all object files and compile the whole stuff new? I received
> linker errors...
> I attach the head file, but I think it is o.k....
> Regards,
>         Stephan
> P.S.: I hope to get it all solved. But if not, I really would like to
>         ask you for the binaries. You will see the "progress" on one
>         of the web pages...
> Stephan Eickschen                     Tel. : +49 (0)251 83-34704
> Westfaelische Wilhelms-Universitaet   Fax. : +49 (0)251 83-36100
> Institute for Geophysics
> Research Unit of Physical Glaciology  email: eicksch at uni-muenster.de
> Corrensstrasse 24
> 48149 Muenster
> Germany
> # read documents/instructions/platforms/sgi.html !
> CC                  = cc
> FC                  = f77
> LEX                 = lex
> YACC                = yacc
> #LEX                 = flex
> #YACC                = bison -y
> ARCH                = sgi
> #GISBASE             = /usr/local/grass
> #UNIX_BIN            = /usr/local/bin
> GISBASE             = /exports/sgi/GRASS/grass4.1.2
> UNIX_BIN            = /exports/sgi/GRASS/grass4.1.2/bin
> DEFAULT_DATABASE    =
> DEFAULT_LOCATION    =
> LDFLAGS             = -s
> XLDFLAGS            = -lPW
> XINCPATH            =
> XMINCPATH           =
> XLIBPATH            =
> XLIB                = -lX11
> XTLIB               = -lXt
> XMLIB               = -lXm
> XEXTRALIBS          = -lPW
> TERMLIB             = -ltermlib
> MATHLIB             = -lm
> USE_FTIME           =
> VECTLIBFLAGS        =
> XDRLIB              = -lsun
