probleme opening monitors
Michel Wurtz - LTE mw at engees.u-strasbg.fr
Fri Jun 26 03:02:00 EDT 1998
Karine ZUERCHER wrote:
> X Error of failed request:  BadMatch (invalid parameter attributes)
>   Major opcode of failed request:  78 (X_CreateColormap)
>   Serial number of failed request:  30
>   Current serial number in output stream:  31
This message generally occurs when you use XDRIVER with a X-windows
server in true color (16 or 24 bits)... You have two choices :
	- use a 256 color X-windows server (and have a bigger
	logical screen	size...
	- use XDRIVER24 instead of XDRIVER (better solution, works
	with all X11 color models
BTW, another question : why still distribute XDRIVER ? Looking at
sources, XDRIVER24 is just an enhancement of XDRIVER, and may be
considered as the current version... another thing to clean...
Michel Wurtz    ENGEES - Laboratoire Territoires & Environnement
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.25.34.62  Fax: +33 03.88.37.04.97
