C++ in GRASS
Angus Carr apcarr at FLASH.LakeheadU.CA
Fri Nov 13 13:23:14 EST 1998
The C++ compilation should not work because C++ is a lot less forgiving
about the headers of each function definition.
C++ can call C functions quite happily, so it's just a matter of the
headers not compiling in. When I did this, I just modified the header
files as I needed them.
Angus Carr.
On Fri, 13 Nov 1998, Olaf Hellwich wrote:
> Hi GRASS programmers,
> Does anybody know how to incorporate C++ code into GRASS programs?
> We tried to use g++ instead of gcc and moved our source to a .cpp
> filename ... only realizing that compilation failed with a bunch
> of error messages. So this doesn't seem to be a promising way.
> Thanks for your help.
> Olaf
