PostGRASS is alive!
Carl Anderson candrsn at mindspring.com
Fri Nov 20 19:58:53 EST 1998
On 20-Nov-98 Der-Johng Sun wrote:
> Hi, all
> I have compiled the postgrass on linux RH5.1.
> But it have Error Message: PG_HOST not set when I run g.select.pg or
> g.table.pg ...
YES! you found a bug
until I post a new version on the weekend
use
g.gisenv PG_HOST={your Postgres host}
if  Postgres is running local, use localhost
ie. g.gisenv PG_HOST=localhost
E-Mail: Carl Anderson <candrsn at mindspring.com>
Date: Sat, 20-Nov-98 12:00:00 +0000 (GMT)
Time: 19:55:22
This message was sent by XFMail
