colors in vector maps
Malcolm Williamson malcolm at cast.uark.edu
Mon Nov 23 19:09:15 EST 1998
Hi, Rainer,
Although GRASS vector maps don't lend themselves to having multiple
colors, check out d.vect.cat.
	-Malcolm Williamson
On Mon, 23 Nov 1998, Rainer Trusch wrote:
> Hello everybody,
> I was just digitizing a map with v.digit. After labeling and adding categories
> I came to the point of adding colors to the different categories, but I
> couldn´t find a hint about a module to do that (most of the tutorials are
> dealing with the procedure of digitizing). How can I do that for display as well
> as prints?
> Is there any possebility to generate a postscript file with ps.map or other
> modules instead of sending the map straight to the printer?
> Thank you
> Rainer
