IDRISI ascii format import
Aqbal Rail aqbalrail at hotmail.com
Tue Nov 24 04:57:37 EST 1998
Hi there,
I would like to obtain the tool to convert arc info .e00 format to Grass
formats. I would very much appreciate it, if you could point out some
tips on how to convert .e00 format to grass format.
Thanks in advance for your help.
Cheers
Aqbal Rail
Dept of Hydraulics & Hydrology
Fac. of Civil Engineering
University of Technology Malaysia
Tel   : 607-5576160 ext 3026
Email : aqbal at tech.fka.utm.my
>I finally found a tool to convert e00 format ARC/INFO files to
>something more usable (ECV2000 tool. Runs only on Win through :(
>Now, how do I get the info from the resulting IDRISI .dvc and .vec into
>Grass? I read that IDRISI binary .img files can be used directly, but
what
>about these ascii files?
>There is a v.out.idrisi module that will produce exactly the same
format
>(.dvc & .vec) in an idrisi directory of the current mapset. But there
is
>no corresponding v.in.idrisi.
>So there must be a simple solution, only I haven't found it. So I ask.
>regards
>MHu
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
