ps.map
Francisco Estrada Belli fncesbl at crsa.bu.edu
Mon Oct 19 18:53:20 EDT 1998
Dear Friends and Grass Experts,
I am having trouble with the printing. I am trying to print two simple vector
coverages in 1:2000 scale using a Lexmark Optra S1620 laser printer.  The paper
size is US letter 8.5X 11. I have tried the ps.map command with the mapping instruction file and with the interactive mode but the result is always the same, Grass selects the default scale setting which will fit all in one panel (1:5070).
Now, I run ps.select to select the above printer, and I made a descrition file
using the defaults from the manual :
level: 1
page width: 8.5
page height: 11.0
top margin: 0.5
bottom margin: 0.5
left margin: 0.25
right margin: 0.25
resolution: 75
