GRASS 4.2.1 lock file problem
Charles Dingman cdingman at his.com
Mon Apr 12 22:24:03 EDT 1999
On Mon, 12 Apr 1999, you wrote:
>> From: Charles Dingman <cdingman at his.com>
>> "/usr/local/grass42/etc/GIS.sh:  /usr/local/grass42/etc/lock:  No such
>> file or directory
>> Unable to properly access /home/cdingman/.gislock
>> Please notify system personel."
>Hi,
>sorry for this problem! Please try the following:
>   Create locks-directory (the directory must have the name
>   of your machine). If you don't know it name, type:
>        uname -n
>   The first word is the machine's name. Example:
>     hgeo02.geog.uni-hannover.de  -> hgeo02
>   Proceed with:
>      cd locks
>      mkdir "machine_name"     (the machine must have a name, not "localhost")
>      cd ..
>      chmod -R 1777 locks
>   Example:
>      cd locks
>      mkdir hgeo02
>      cd ..
>      chmod -R 1777 locks
>Note, that the command order was changed in opposite to the
>installation manual. If this helps or not, please let me know.
>We will find a solution!
>With regards
>  Markus Neteler
Thanks.  I had that mostly--locks was 0755 and cdingman was 1777.
I still get the same message after making the change you recommended.
