grass termlib problems
Micron.Net bahoover at micron.net
Tue Apr 20 23:33:13 EDT 1999
Looks like you are using solaris.  Comment out the comment out the TERMLIB
statement
#TERMLIB        = -ltermlib
this should work.
attached is my header file for solarisx86 2.6.  It should also work for the
sparc version of solaris
-----Original Message-----
To: grassu-list at cecer.army.mil <grassu-list at cecer.army.mil>
Date: Tuesday, April 20, 1999 7:10 PM
Subject: grass termlib problems
>Can anyone help us with the following problem?...
>If we specify "-ltermlib" for the TERMLIB option while running the setup
>script (the relevant part of the "head" file is below), then we get a
>compiler error telling us that there are multiple definitions for
>Def_term.  However, if we leave that option blank, we get "undefined
symbol"
>errors.  The multiple definition errors are pasted below.
>TERMLIB             = -ltermlib
>CURSES              = -lcurses $(TERMLIB)
>MATHLIB             = -lm
>Compile error:
>/usr/ucb/cc -s -o /usr/local/grass42/etc/bin/main/inter/d.3d OBJ/main.o
>OBJ/threed.o OBJ/transform.o OBJ/clip.o  OBJ/get_range.o OBJ/check_opt.o
>OBJ/get_inputs.o OBJ/sigint.o OBJ/get_row.o OBJ/draw_face.o
>/home/jenny/src42/src/libes/LIB/libD.a
>/home/jenny/src42/src/libes/LIB/libdisplay.a
>/home/jenny/src42/src/libes/LIB/libraster.a
>/home/jenny/src42/src/libes/LIB/libgis.a
>/home/jenny/src42/src/libes/LIB/libvask.a -lcurses -ltermlib -lm
>ld: fatal: symbol `Def_term' is multiply defined:
>        (file /usr/ucblib/libcurses.a(curses.o) and file
>/usr/ccs/lib/libtermlib.a(setupterm.o));
>ld: warning: symbol `ttytype' has differing sizes:
>        (file /usr/ucblib/libcurses.a(curses.o) value=0x32; file
>/usr/ccs/lib/libtermlib.a(setupterm.o) value=0x400);
>        /usr/ccs/lib/libtermlib.a(setupterm.o) definition taken
>ld: fatal: File processing errors. No output written to
>*** Error code 1
>make: Fatal error: Command failed for target
>`/usr/local/grass42/etc/bin/main/inter/d.3d'
>GISGEN failure at STEP: src/display/d.3d
>TIA,
>Maribeth
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19990420/0305ff40/solaris.obj
