We can't import more than 49 files
R. Joe Brandon rjoe at cast.uark.edu
Thu Apr 22 12:31:03 EDT 1999
Malcolm,
Whenever I have had to do large sets of maps I use a syntax in my shell
such as:
r.patch input=All.Prehistoric.Sites,395-573.p.poly,400-568.p.poly,408-607.p.poly
,409-597.p.poly,410-606.p.poly,412-601.p.poly,414-583.p.poly,414-601.p.poly,414-
609.p.poly output=patch1
etc... and then patch the maps together.  Is this the style you are
suggesting or would you suggest that they have an actually variable such as
r.patch input=$
R. Joe
On Thu, 22 Apr 1999, Malcolm Williamson wrote:
> On Thu, 22 Apr 1999, Utente Grass wrote:
> > Thank you for your message. The real problem was format errors in ascii data.
> > We've resolve them and we 're able to  import 215 files.
> > Now we are trying to patch them all together but r.patch allows only 10 files in
> > input. It is possible to change the source without create new problems?
> > Good bye
> > Valentina & Marco
> You could modify the code for r.patch, but there is also a limit on how
> many files may be open at a time in GRASS, something like 27. Your best
> bet is simply to right a basic shell script that loops through r.patch,
> creating temporary patched files from 10 layers at a time, and then
> patching those together. Not a big deal. If you plan on doing much work
> in GRASS, you'll want to learn how to do this anyway.
> Regards,
> Malcolm D. Williamson - GIS Specialist         E-mail: malcolm at cast.uark.edu
> Center for Advanced Spatial Technologies        Phone: (501) 575-6159
> Ozark Rm. 12                                      Fax: (501) 575-5218
> University of Arkansas
> Fayetteville, AR 72701                            Web:
> http://www.cast.uark.edu
R. Joe Brandon
Center for Advanced Spatial Technologies           (fax) 501 575-5218
Rm. 12 Ozark Hall                                        501 575-4277
University of Arkansas                             rjoe at cast.uark.edu
Updated! -> http://www.cast.uark.edu/~rjoe
Computers are actually powered by Chaos theory, not electricity...that
is just for the fan.  (T. Hesser)
