grass on windows via cygwin (or interix(opennt) ?
Angus Carr apcarr at FLASH.LakeheadU.CA
Tue Apr 27 15:13:16 EDT 1999
I had a moment of madness in idleness, and had a kick at this. It isn't
hard in principle. I had to get ncurses set up, and some other things. I
got distracted by my real job, so I had to stop.
I am a Linux geek who has to work in ArcView, so I used this compiler to
develop a DLL for ArcView. The compiler works fine at compiling programs
originally built for Unix.
Keep in mind that I did not succeed, but that was not from the difficulty
of the task.
The real problems you will encounter :
FIFO's are not supported by the cygwin dll. You will need to modify the
XDRIVER and libraries to use a shared memory message-passing method. Check
out MessQ if you want to do this. It was for this very purpose.
After downloading the compiler, you will also need curses, the X libraries
and one or two other things. Not a problem, but slightly frustrating to be
constantly downloading.
Angus Carr.
ps. For those of you who don't know of the compiler to which Bob refers,
it is a free GCC based compiler for Win32 platforms. It supports most
components of the Unix API, and seems to do a good job, even of those
components that do not exist in Windows (like symbolic links...). It is
available at http://www.cygnus.com/misc/gnu-win32
On Tue, 27 Apr 1999, Robert L. Sandefur wrote:
> Hi- I stumbled across cygwin which is free and allegedly allows unix apps to be ported to windows- Has any one tried to get grass to run on cygwin? ( I tried opennt (now interix) and the compile was very messy (for me).
> Thanx
> bob sandefur
