tcltkgrass errors
arch. Stefano Maffulli stefano.maffulli at DPMPE.UNIFI.IT
Tue Aug 10 10:49:13 EDT 1999
***** REPOST ??? ********
Hello all
it looks like this message never got to the list.  If you have seen this
already,please let me know. I regularly receive the grass list, but
never got this message from it.
Original message:
Hello all
I managed to setup grass on a SPARCstation 20 running solaris2.6 and
CDE.  Grass works fine (I am going through the ASSIST tutorial) but I
get errors when trying to run the tcltkgrass.
I installed the grass4.21 bin21 for solaris2.6, did not compile by
myself.
The error i have only happens when i run it as simple user and doesn't
show up if i login as root.  Here is the message i get:
Mapset <stef> in Location <leics>
GRASS-GRID > Error in startup script: couldn't create error file for
command: no such file or directory
    while executing
"exec xwininfo -id [winfo id .w_g] | grep -i Corners"
    (file "/usr/local/grass42/tcltkgrass/main/gui.tcl" line 1511)
    invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
    (file "/usr/local/grass42/bin/tcltkgrass" line 17)
I suppose it is related to writing permissions. Is it safe to allow
writing for all users?  Right now I am the only user of this machine so
I guess I could do that, right?
 The distribution I used had tcltkgrass included. I also tried to untar
the tcltkgrass distributed separately but with no luck.  I have wish8.0.
Thank you for help
Stefano Maffulli
******  NEW e-mail ADDRESS! UPDATE YOUR ADDRESS BOOKS  ******
GIS_L.A.B. Land Application Builders - VicePresident
Centre for Interdisciplinary Research and Application of GIS
Via S. Niccolo' 89/a 50121 Firenze Italy
tel. +39 055 2491.533     Fax +39 055 2345.328    ICQ# 39845203
To err is human...to really foul up requires the root password.
