GRASS5.0beta2 compiled on SGI Origin 2000
Justin Hickey jhickey at impact1.hpcc.nectec.or.th
Wed Aug 11 09:58:26 EDT 1999
Hello all
Last week I was asked to post this so here it is. We recently compiled
grass5.0beta2 on our SGI Origin 2000 running IRIX 6.5. The compile was full of
thousands of warnings, but only 19 changes were required to compile it error
free. These changes are attached with the reasons we thought caused the errors
for anyone who is interested. There was a change that we had to make to the
configure script but I'm not sure if it is a good change since we are not
familiar with how confuigure scripts work.
One thing to note was that we used the SGI compilers with the option for
parallelizing code if it was possible. This option didn't effect the compile of
the program in terms of causing errors but we are not sure if it has provided
any benefit. So far, d.rast using the spearfish database seemes to use multiple
processors but the time is about the same as a single processor. Also
r.surf.contour does not appear to use multiple processors but then again, we
never had it run completely (see the previous post).
Hope this is useful to someone.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
Changes made to code and other files to get grass to compile on SGI Origin 2000
IRIX 6.5 with vendor compilers
1.
    First see changes to the configure script from the error reported in step 6
    below.
    Added a compiler flag to attempt to parallelize the code. Added -apo to the
    COMPILE_FLAGS (line 13) and LDFLAGS (line 14) definitions in the file
    grass5.0beta2/src/CMD/head/head after running the configure script.
2.
    Module: grass5.0beta2/src/libes/bitmap
    File:   grass5.0beta2/src/include/bitmap.h
    Error:  line 23: error(1079): expected a type specifier
      	    	// char *token;
    Fix:    This is a C++ comment not a C comment - changed code to C comment
3.
    Module: grass5.0beta2/src/display/devices/lib
    File:   SWITCHER.c
    Error:  line 899: error(1133): expression must be a modifiable lvalue
            	if ((stat=get1(((char* )buf)++)) != 0)
    Fix:    The buf variable is being cast and incremented but the result of the
    	    cast is not stored. This is dangerous since types of pointers
	    being used may be of different size. If they are different in size
	    then buf is not aligned properly for it's next access. For example
	    if buf is initially an int pointer (32 bits) and the cast and
	    increment above are performed twice, then buf no longer points to a
	    proper int. Therefore buf needs to be cast to another temporary
	    variable for incrementing. Changed code from
	        int stat;
     	    	while (n-- > 0)
	    	    	return stat; /* EOF or COMMAND_ESC */
    	    	return 0;
    	    to the folowing:
		int stat;
    	    	char *tempBuf;
    	    	tempBuf = (char* )buf;
     	    	while (n-- > 0)
            	    if ((stat=get1(tempBuf++)) != 0)
    	    	return 0;
4.
    File:   font.c
    Error:  line 119: error(1133): expression must be a modifiable lvalue
            	(char)*a++ = *b++;
    Fix:    This is the same as for SWITCHER.c in error 2 above. The only call
    	    for the function for this line of code is commented out with a
	    statement concerning alignment errors (see the discussion for the
	    fix in error 2 above). So the function X_copy was commented out
	    since it is a static function and can only be called from within
	    the same file. Also the prototype at line 14 was commented out.
5.
    Module: grass5.0beta2/src/display/devices/XDRIVER/XDRIVER24
    File:   SWITCHER.c
    Error:  line 141: error(1029): expected an expression
      	    	debug("Initialize Graphics");
	    Plus 16 more of the same (ie every call to debug)
    Fix:    These errors are caused by having the debug call defined as a C++
    	    comment on line 35. Since DEBUG is not defined, all the calls to
	    debug are replaced with C++ comments. To fix this the else part of
	    #ifdef DEBUG was defined to contain an empty function. Changed line
	    35 from:
	    	#define debug //
    	    to the following:
	    	#include <stdarg.h>
    	    	int debug(char *x,...) {}
6.
    Module: grass5.0beta2/src/general/g.help
    File:   menu.c
    Error:  line 742: error(1565): struct "_win_st" has no field "NONE"
            	Maxlines = ((short)Numlines <= Windoname->CURSES_MAXY) ?
	    line 743: error(1565): struct "_win_st" has no field "NONE"
            	Numlines : Windoname->CURSES_MAXY;
	    line 814: error(1565): struct "_win_st" has no field "NONE"
	    line 815: error(1565): struct "_win_st" has no field "NONE"
    Fix:    The NONE value is defined due to an error found in code generated by
    	    the grass5.0beta2/configure script. The code in the configure script
	    checks the WINDOW structure in curses.h and is as follows starting
	    from line 2322:
	    	CURSES_MAXY=NONE
    	    	cat > conftest.$ac_ext <<EOF
    	    	#line 2325 "configure"
    	    	#include "confdefs.h"
    	    	    #include <curses.h>
    	    	    WINDOW w;
    	    	int main() {
    	    	void t () { w.maxy = 0; }
    	    	; return 0; }
    	    	EOF
    	    and again starting at line 2342:
    	    	#line 2344 "configure"
    	    	    #include <curses.h>
    	    	    WINDOW w;
    	    	int main() {
    	    	void t () { w._maxy = 0; }
    	    	; return 0; }
    	    	EOF
	    The problem with this code is that it generates an error due to the
	    definition of the function t() inside main(). C does not support
	    nested functions. This error was reported in the config.log file.
	    The solution for this error was to delete the t() function
	    definition in the configure script. As well, the same definition was
	    found in the configure.in file and was deleted from that file as
	    well. This was done since we do not really know how configure works
	    so we deleted both instances of the code to ensure that the fix
	    worked. Another solution may be better, but this one worked for us.
	    The following is the new code:
	    	CURSES_MAXY=NONE
    	    	    #include <curses.h>
    	    	    WINDOW w;
    	    	int main() {
    	    	w.maxy = 0;
    	    	; return 0; }
    	    	EOF
	    then at line 2342
    	    	    #include <curses.h>
    	    	    WINDOW w;
    	    	int main() {
    	    	w._maxy = 0;
    	    	; return 0; }
    	    	EOF
7.
    Module: grass5.0beta2/src/imagery/i.gensig/inter
    File:   Gmakefile
    Error:  ld32: ERROR 33: Unresolved text symbol "mp_in_parallel_region" --
    	    1st referenced by
	    /usr1/grass/grass5.0beta2/src/libes/LIB.mips-sgi-irix6.5/libgis.a
	    (null_val.o).
	    Plus 3 more of the same
    Fix:    Since we are using the -apo option for parallel processing, the
    	    LDFLAGS are required on the command line. This Gmakefile does not
	    specify the LDFLAGS variable in the cc command line so it was added
	    as follows:
	    	$(CC) $(LDFLAGS) main.o $(LIBES) $(VASK) $(MATHLIB) $(XDRLIB)
8.
    Module: grass5.0beta2/src/imagery/i.gensigset/cmd
    File:   read_data.c
    Error:  line 3: error(1166): expected a declaration
    	    // #include "local_proto.h"
9.
    Module: grass5.0beta2/src/imagery/i.gensigset/inter
    File:   Gmakefile
    	    1st referenced by
	    (null_val.o).
	    as follows:
10.
    Module: grass5.0beta2/src/imagery/i.rectify3/cmd
    File:   protodefs.h
    Error:  line 82: error(1166): expected a declaration
    	    //void CRS_georef2(...);
	    line 83: error(1166): expected a declaration
    	    //int CRS_georef(...);
	    line 84: error(1166): expected a declaration
    	    //int CRS_compute_CP_georef_equations(...);
    Fix:    These are C++ comments not C comments - changed code to C comments
11.
    Module: grass5.0beta2/src/mapdev/georef
    File:   ../digitizers/dig_inter.h
    Error:  line 76: error(1166): expected a declaration
    	    // int jtimeout(void);
	    line 90: error(1166): expected a declaration
    	    //int delay(int n);
12.
    Module: grass5.0beta2/src/mapdev/v.in.dxf
    File:   Gmakefile
    	    1st referenced by OBJ.mips-sgi-irix6.5/which_layer.o.
    	    LDFLAGS are required on the command line. This Gmakefile redefines
	    the LDFLAGS to nothing so this line (line 6) was commented out.
13.
    Module: grass5.0beta2/src/misc/m.proj
    File:   local_proto.h
    Error:  line 2: error(1166): expected a declaration
    	    // int get_enz(void);
	    Plus 17 more at lines 3-12, 14, 15, 17, 24, 26, 27, and 28
14.
    Module: grass5.0beta2/src/paint/Interface/driverlib
    File:   interface.c
    Error:  line 375: error(1133): expression must be a modifiable lvalue
            (char *)buf += i;
    Fix:    Alignment problems like those in error from step 3 above. Code was
    	    changed from the followinmg:
	    	int i;
    	    	while (n > 0)
	    	    i = read (0, buf, n);
	    	    if (i == 0)
	    	    	paint_error ("unexpected EOF");
	    	    if (i < 0)
	    	    	paint_error ("read error");
    	    	    (char *)buf += i;
	    	    n -= i;
	    to the following:
	    	int i;
    	    	char *tempBuf;
    	    	tempBuf = (char*) buf;
    	    	while (n > 0)
	    	    if (i == 0)
	    	    if (i < 0)
    	    	 /* (char *)buf += i;*/
	    	    tempBuf += i;
	    	    n -= i;
15.
    Module: grass5.0beta2/src/paint/Programs/p.map.new/cmd
    File:   text.h
    Error:  line 37: error(1166): expected a declaration
    	    // int graph_text(...);
16.
    Module: grass5.0beta2/src/raster/r.cost/cmd
    File:   local_proto.h
    	    // int check_all(char *);
	    line 5: error(1166): expected a declaration
    	    // int time_to_stop(int, int);
17.
    Module: grass5.0beta2/src/raster/r.mapcalc/mapcalc
    File:   maps.c
    Error:  line 336: error(1133): expression must be a modifiable lvalue
            (char *)values = vbuf, sizeof(vbuf));
    Fix:    Alignment problems but this time the cast was being performed before
    	    the assignment. Therefore parentheses were added to the assignment
	    as follows:
	    	(char *)(values = vbuf), sizeof(vbuf));
18.
    Module: grass5.0beta2/src/raster/r.poly/cmd
    File:   io.c
    Error:  line 100: error(1166): expected a declaration
    	    //static struct area_table *areas;
19.
    Module: grass5.0beta2/src/sites/s.surf.rst/v.surf.rst
    File:   main.c
    Error:  line 607: error(1029): expected an expression
            &xmin, &xmax, &ymin, &ymax, &zmin, &zmax, &NPOINT); // , dmax);
20.
    Module: grass5.0beta2/src/sites/s.territory
    File:   main.c
    Error:  line 191: error(1029): expected an expression
            G_site_put (out_sfd, outsite); // , (rtype != -1));
