tcltkgrass errors SOLVED
arch. Stefano Maffulli stefano.maffulli at DPMPE.UNIFI.IT
Tue Aug 17 04:58:20 EDT 1999
hello all
I finally solved the problem with TclTkGrass under Solaris 2.6: it was
due to a write permission problem in the dir /var/tmp.  I originally
thought that the temp dir was /tmp, but this doesn't seem the sun's idea
I had to change the owner of the dir to allow root to change the
permissions (it belonged to 310 ?!?  wonder what that is :-))  Now all
works fine.  I discovered the trap trying to view the set output with vi
and vi complained that could not write to /var/tmp.
Thank you for your patience
Stefano Maffulli
"Jeff P. Hollenbeck" wrote:
> I had a similar, yet not identical, experience once.  I finally found that
> the problem was the .tmp (hidden dir) in my mapset that had root only
> permissions.  Its worth checking...
> On Mon, 16 Aug 1999, Bernhard Reiter wrote:
> > On Mon, Aug 16, 1999 at 08:04:50AM -0100, arch. Stefano Maffulli wrote:
> > > I am only able to run tcltkgrass
> > > interface if I login as root!
> > > If I login as another user it starts
> > > drawing a window, then it stops and gives the error:
> > > Mapset <stef> in Location <leics>
> > > GRASS-GRID > Error in startup script: couldn't create error file for
> > > command: no such file or directory
> > >     while executing
> > > "exec xwininfo -id [winfo id .w_g] | grep -i Corners"
> > >     (file "/usr/local/grass42/tcltkgrass/main/gui.tcl" line 1511)
> > >     invoked from within
> > > "source $env(TCLTKGRASSBASE)/main/gui.tcl"
> > >     (file "/usr/local/grass42/bin/tcltkgrass" line 17)
> > > I checked the permission for /tmp and it seems ok: owner+group+other has
> > > rwx permissions.  Also the program xwininfo works if invoked.
> > > What else can it be?
> > Some environment variable, like PATHs, TCLTKGRASSBASE might be different
> > vor the user and for root. Check the output of the "set" command and
> > compare it.
> > On Mon, Aug 16, 1999 at 12:48:35PM -0100, arch. Stefano Maffulli wrote:
> > > I am clueless now.  What else can it be?  Is there any Solaris user out
> > > there that can give some advice?
> > It is hard to do that, without actually looking into your problem on
> > your particular machine.
> > You might consider a fresh new install, to see if the problems are still
> > there.
> >       Bernhard
> > Research Assistant, Geog Dept UM-Milwaukee, USA.    (www.uwm.edu/~bernhard)
> > Association for a Free Informational Infrastructure              (ffii.org)
