Using GRASS commands form unix prompt
Conn Copas conn.copas at dsto.defence.gov.au
Wed Jan 27 00:46:17 EST 1999
"Justin Hickey" <jhickey at impact1.hpcc.nectec.or.th> writes:
> > Is there a way of setting up GRASS so that I can use the GRASS commands
> > directly from the UNIX prompt. I faintly recall that there was some
> > suggestion for doing this sometime on this ML but I am unable to locate the
> > answer now.
> Why can't you use the standard grass commnad line interface (running
> grass4.2.1)?
Possibly because it is desired to issue Grass calls from within a program,
rather than interactively. There has been previous discussion on setting
environment vars so that these calls may be issued, but parsing the output
remains as a sometimes tricky problem.
