GRASS5.0beta2 fix for raster/r.mapcalc/polish
egm2 at jps.net egm2 at jps.net
Sat Jul 31 16:40:34 EDT 1999
On 31 Jul, Bill Hughes wrote:
  |  Eric G. Miller writes:
  |  > pol.y:43: warning: previous implicit declaration of `mapname'
  |  > pol.y:89: `storage' used prior to declaration
  |  > When I see "implicit declaration" I think, missing header include.  I
  |  > haven't found the fix for this one. There seems to be a problem with the
  |  The implicit declaration is because the header is #included in the C
  |  code instead of the YACC part.  The warning is harmless, but it can be
  |  fixed by placing the following fragment at line 10 and deleting the
  |  first three includes at line 79.
  |  #include <stdlib.h>
  |  #include <string.h>
  |  #include "local_proto.h"
  |  The error that stops the compile is the 'storage' declaration.  This
  |  can be fixed by moving the line that defines the 'storage' variable
  |  up to just after the #include-s.  Approx. Line 149 to Line 78.
  |  The lines to move are:
  |  static int nstored = 0;
  |  static char **storage = 0;
  |  This will allow the compile to proceed.
  |  Bill Hughes
That mostly worked. I had to move that static declarations with the
#include-s
#include <stdlib.h>
#include <string.h>
And then leave the #include "lex.yy.c" where it was.  It then compiled
fine.  Now onto the next error...
Eric G. Miller
Powered by the POTATO (http://www.debian.org)!
