DXF Import problem
Johnny Duke jduke at ar.nrcs.usda.gov
Fri Mar 12 10:07:38 EST 1999
Michel Wurtz - LTE wrote:
> I have a DXF file (geologic map) which doesn't import on Grass.
> v.in.dxf runs Ok, says 100% done, quit gracefully and...
> no file, nada, niet, rien  :-((((
> I tested the same DXF for import on other GIS (GeoConcept) or
> tools (Surfer) and it worked.
> This DXF was created with Mapinfo.  Any similar experience ?
> Is v.in.dxf bugged ? (v.in.dxf3d doesn't give any file, too)
> Any helpfull advive will be greatly appreciated !
> Michel Wurtz    ENGEES - Laboratoire Territoires & Environnement
>                 1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
>                 Tel: +33 03.88.24.82.45  Fax: +33 03.88.37.04.97
Michel,
When you run v.in.dxf, the first thing it does is converts it to a
dig_ascii file.  Your file from v.in.dxf is in the dig_ascci directory.
Then you will run v.in.ascii.  This sould get you file in
good luck
Johnny Duke
Gis Tech
USDA/NRCS
USA
