avhrr level 1b data from saa, how to unpack?
Alexander Brauns conappro at quetzal.net
Fri Mar 19 09:51:53 EST 1999
does anyone have a hint on how to unpack avhrr hrpt data from noaa
satellite active archive (SAA)? the data is provided via ftp in 8 or
10bit format, but the files are packed in some obscure way, the relevant
documentation (POD-polar orbital data guide) does only provide a fortran
routine for unpacking, I wonder if anyone already has a solution to this?
the images are intended for wildfire monitoring in northern guatemala
help would be appreciated
victor hugo ramos, alexander brauns
centro de monitoreo y informacion - cemec -
conap region VIII, peten, guatemala
tel +502-9260809
fax +502-9260812
e-mail: conappro at quetzal.net
