s.in.ascii
Henk Coetzee henkc at geoscience.org.za
Mon Oct 4 08:44:48 EDT 1999
Markus Neteler wrote:
> Hi Henk,
> you need a preceding "#" character for the z-value.
> To overcome the problem easily do following:
> * In GRASS 4.2.1 use
>    s.in.ascii.dem instead of s.in.ascii
> * In GRASS 5 use
>    s.in.ascii -e
> This will add the required characters.
Thanks
This is what I have tried. I get a file with rows that look like:
23:19:51E|17:44:16.98S|%579
But s.surf.idw tells me "s.surf.idw: no data points found"
Cheers
Henk
Henk Coetzee
Geophysics Unit
Council for Geoscience
Private Bag X112, Pretoria, 0001, South Africa
Tel: +27-12-841-1192   Fax: +27-12-841-1424
