Where do I get a ppm driver?
Linda Moet lindam at gwnsys.ca
Mon Oct 4 19:05:48 EDT 1999
Thanks for your quick reply.  After I posted my question, I found the
command that does what I need:
    r.out.ppm input=raster_file output=ppm_file
No ppm driver required.  I don't know how I missed it when I was surfing
through the manual pages.  =+\
Best regards,
Linda Moet
GWN Technologies
lindam at gwnsys.ca
-----Original Message-----
From: Michel Wurtz - ENGEES/CEREG <mw at engees.u-strasbg.fr>
To: grass at cecer.army.mil <grass at cecer.army.mil>
Date: Monday, October 04, 1999 1:09 AM
Subject: Re: Where do I get a ppm driver?
>Linda Moet wrote:
>> I would like to save a GRASS raster map as a ppm.  The following should
>> work:
>> p.select ppm
>> p.map.new input=map_script
>> ...but I don't have a ppm driver in /path_to_grass/etc/paint/driver.  I
just
>> have "preview" and "preview2".  I am running GRASS 4.2.1 on Red Hat Linux
>> 5.2.  I did not compile GRASS myself, I just downloaded the binaries.
Just
>> to make sure I am on the right path, I did the following:
>> p.select preview
>> ...after writing a file called map_script, of course.  It worked, so I am
>> sure that my only problem is finding a ppm driver.  If anyone can point
me
>> in the right direction, I would be very grateful.
>You can also use the CELL driver (redirect d.mon in a Grass raster
>file),
>then export the grass raster file in tiff (or something else), then
>use xv (or imagemagik, or pbmplus) to convert your tiff file in ppm.
>Not a direct way, but that may be batched too.
>My 0.02$... (or should I say Euro?)
>Michel Wurtz    ENGEES - CEREG
>                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
>                Tel: +33 03.88.24.82.45  Fax: +33 03.88.37.04.97
