hdf (compiling)
Agustin Lobo
alobo at ija.csic.es
Tue Oct 5 10:54:46 EDT 1999
Markus,
1. The README still says that we should compile with gmake4.1, is this
true or is it outdated?
2. I don't see any MAKE.* for linux, should we make one or does the
Gmakkefile take care?
Thanks
Dr. Agustin Lobo
Instituto de Ciencias de la Tierra (CSIC)
Lluis Sole Sabaris s/n
08028 Barcelona SPAIN
tel 34 93409 5410
fax 34 93411 0012
http://pangea.ija.csic.es/alobo
On Tue, 28 Sep 1999, Markus Neteler wrote:
> > Agustin,
> > The module is r.in.hdf and is present in your 4.2 version.
> > It's command-line and we use it to import NWS NEXRAD
> > data into GRASS. While it's not present in 5.0beta, it
> > *should* compile there. It will generate 4.x format files.
> > We're working on fp conversions for all 4.x modules, but
> > this is a slow process due to our current work loads. LEt
> > me know if you need any help with this.
> > Bruce
> Hi!
> Concerning GRASS 5: the r.in.hdf/r.out.hdf is in
> src.garden/grass.hdf/
> But it needs a few changes in Gmakefile. Get the updated
> package here:
> ftp www.geog.uni-hannover.de
> cd /incoming
> grass.hdf.tar.gz
> (ftp://www.geog.uni-hannover.de/incoming/grass.hdf.tar.gz)
> It is not yet updated to floating point support (any volunteers?).
> But I could successfully import satellite data in HDF format.
> Best regards
> Markus Neteler
