Merging DEM's
aanderson = aanderson3 at uswest.net
Fri Oct 8 15:18:28 EDT 1999
I have had some success at reading 7.5 min USGS DEMS, using
Sol Katz's routines which I had to modify to fix some alignment
problems when joining maps together. I have also been able to
use the DLG's from the same source.
Have you tried Katz's stuff?
try:
http://ftp.blm.gov/pub/gis/sdts/dem/old/sdts2dem.tgz
which also use the fips123 lib at
http://sdts.er.usgs.gov/pub/sdts/software/fips123/fips123*.gz
Good luck
On Fri, 08 Oct 1999, you wrote:
> I'm having nothing but trouble trying to import USGS DEM's, either 7.5 type
> or 1 degree versions, into my GRASS5 using m.dem.extract.  Errors include
> "data not found in correct file" and m.rot90 subroutine not finding file to
> work on.
> Anyone out there who uses this command regularly I could talk to in an
> effort to get it to work for me?  Many thanks, tom at bluesky.org
			From Al Anderson
_______________________________________________________
- Anything NOT worth doing..is NOT worth doing well! AA
