grass5b3 install problem
Michel Wurtz - ENGEES/CEREG mw at engees.u-strasbg.fr
Wed Oct 13 04:21:15 EDT 1999
jiao weili wrote:
> Hi,
> I downloaded grass5.0beta3 and try to compile it. I got failed at: src/display/d.3d.
> The error message as
> In function 'V_call':
>  Vcall.c:150/160/168/178/... undefined reference to "__waddbytes".
> The same error also appears at src/display/d.color.
The problem is related to your curses package.  I run Linux 2.0.30
(slackware distribution) and had the same problem.  It appears that
the "curses.h" include file is not the one needed for ncurses library.
The workaround I used was to move all the files from
/usr/include/ncurses
to /usr/include (file with same name in /usr/include were renamed
from xxx.h to OLDxxx.h)
I hope this can solve your problem.
Michel Wurtz    ENGEES - CEREG
                1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
                Tel: +33 03.88.24.82.45  Fax: +33 03.88.37.04.97
