NVIZ2.2 bugfixes (Grass5.0b3)
Pierre de Mouveaux p_de_mouveaux at hotmail.com
Tue Oct 26 23:38:34 EDT 1999
Hi
here is attached a tar-gziped file, with som updates for bugs I
encountered with NVIZ2.2 in the Grass5.0beta3 distribution:
There are:
Map clicks problems (Line of sight problem).
Spurious redraw of screen when mouse moves over some faders
Site and files selection box was not working.
Move the file nviz2.2-update.tar.gz in your top src directory,
then type the usual:
tar zxvf nviz2.2-update.tar.gz
then read the file NVIZ2.2-UPDATE.
Just in case:
If things don't work for you, you can retrieve the original NVIZ2.2
source files:
go in the directoty *UP* from the top grass5.0 src dir.
Assuming the original Grass5.0 src are in the grass5.0beta3.tar.gz file,
type:
tar zxvf grass5.0beta3.tar.gz grass5.0beta/src.contrib/GMSL/NVIZ2.2
tar zxvf grass5.0beta3.tar.gz grass5.0beta/src.contrib/GMSL/libes
Note: I use Linux (Mandrake 6.0 with updates, like Redhat 6.0).
Hope this helps...
Pierre.
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19991027/afbb0231/nviz2.2-update.tar.gz
