NVIZ2.2
Luca Palmeri lpalmeri at ux1.unipd.it
Wed Sep 15 11:51:22 EDT 1999
Hi Markus
I found the bug and bugfixed it.
Just subsitute the file
                 $GISBASE/etc/nviz2.2/scripts/mapBrowser.tcl
with the one attached to this message.
The bugfix is on lines 32-33 of the file
cheers
LP
Markus Neteler wrote:
> > This question is for those that are using NVIZ.
> > When I select the surface panel and then click on the
> > NEW button in order to add a new layer, and then click again
> > on new from the surface attribute window, I have a window that
> > very likely should give me a list of available mapsets and
> > raster files. Instead the window is empty no mapset, no raster.
> > (My g.gisenv gives mapset=PERMANENT location=adibacc).
> > Moreover if I type in the window the name of an existing raster
> > (for example elev_tps my DEM) and then click on accept, everything
> > goes well and I have my wanderfull 3D elevation map displayed.
> > Does anybody have any suggestions about that or have encountered
> > the same problem.
> > cheers
> > LP
> Hi Luca,
> I have the same problem. BUT: If you enter the name of a map
> directly, it is accepted. So there is a bug in displaying the
> map's names. [how to fix that?]
> Greetings
>   Markus
Type: application/x-tcl
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/19990915/c386963c/mapBrowser.tcl
